It is currently Jan Tue 25, 2022 7:06 pm
 Post subject: Sentinel 6946 s
PostPosted: Apr Tue 06, 2021 11:14 pm
Hi Guy's
Well I finally gave in and went and picked up this
BASKET case 32V radio. The first 32v farm set for me.
Can I use 4, 9V battery's in series giving me 36vdc
on a 32V set?
I was going to use more 9 v battery's 16 in all.
Using 4 sets of 4 in a series/parallel arrangement, to
give me more current?
Also I'm going to have to totally rebuild the cabinet :oops:
I do have some wood working skills :?:
Here's the set.
Gary
 Post subject: Re: Sentinel 6946 s
PostPosted: Apr Tue 06, 2021 11:42 pm
You can't afford to run that radio on 9V batteries. You need to look for a power supply with several amps of output current. If the radio has a vibrator, something with at least 10A of surge capability would be good to get it started. If the radio is 32V only, you can probably get by with a 5A supply. The tube filaments will draw a lot of current when cold so you need a supply that will not go over current on start up.
It appears to be the same chassis as the 6900: https://www.radiomuseum.org/r/sentinel_6900.html
There is no vibrator and you can probably get by with a 3A, 32V, power supply.
Jay
PostPosted: Apr Tue 06, 2021 11:47 pm
What does the nameplate under the center control knob say?
Looks like your gonna need a belt sander and a lot of Bondo. lol
:) Greg.
PostPosted: Apr Wed 07, 2021 12:40 am
It is a brass plated badge SENTINEL.
The other two say TONE and AM/SW
No the set has no vibrator.
Anyone have any idea's as to what wood material to
use, plywood? I mean for the substrate. I plan to buy new
vaneer if I can get the cabinet looking half
descent :)
Yes, If I can get the set to play, I will build a power supply.
I wish I had 1/4 the wood working skills as Fred Taylor has,
His work is genius :!:
Gary
PostPosted: Apr Wed 07, 2021 1:53 am
I converted a similar radio to 120VAC. This is the schematic of the power supply:
I used a power transformer similar to this one and it fit easily under the chassis:
https://www.ebay.com/itm/Avel-Y236103-3 ... 1587713800
Jay
PostPosted: Apr Wed 07, 2021 12:52 pm
Thanks Jay, That looks like just what I want to use :idea:
Gary
Post New Topic Post Reply  [ 6 posts ]  Moderator: sofaslug
