It is currently Jan Thu 20, 2022 3:49 pm
 Post subject: Removing paint overspray from plastic.
PostPosted: Apr Wed 07, 2021 9:54 pm
Hi Folks,
What is the best way(s) to remove spray paint overspray from a plastic radio dial?
Thanks for any help!
 Post subject: Re: Removing paint overspray from plastic.
PostPosted: Apr Thu 08, 2021 3:53 am
Thanks for all the great suggestions and help - problem solved.
PostPosted: Apr Fri 09, 2021 12:42 pm
Just seen this, Im glad you got it. Normally to protect the item, I always start with the most mild way. Soapy water and move up. On plastic after soapy water I would have tried NOVUS No. 1 - Plastic Clean & Shine.
Anyway, what did you find that worked?
Scott
If you can't explain it simply, you don't understand it well enough
A.Einstein
Post New Topic Post Reply  [ 3 posts ]  Moderator: Peter
