Page 1 of 1
[ 10 posts ] |
Author |
drworry
Post subject: HP3465a bench meter Posted: Apr Thu 15, 2021 9:29 pm |
Member |
Joined: Mar Sun 20, 2016 11:04 pm Posts: 1276 Location: Mesa, AZ 85206
Hi Folks
Picked one of these HP 3465a meters up today at a garage sale, and was wondering if I should change the electrolytics....HP usually uses pretty high quality stuff, so it might not be necessary....
Steve
Top |
jimtech
Post subject: Re: HP3465a bench meter Posted: Apr Thu 15, 2021 9:50 pm |
Member |
Joined: Nov Sun 29, 2020 5:59 pm Posts: 480 Location: Carol Stream, Illinois 60188
If I remember correctly, and depending on the power/battery options you have in your meter, there are probably only one or 2 conventional electrolytic capacitors present. The remainder will be either high quality solid tantalum or film types. No shotgun capacitor replacement needed.
Top |
drworry
Post subject: Re: HP3465a bench meter Posted: Apr Thu 15, 2021 11:14 pm |
Member |
Thanks!
The unit looks clean, and fortunately the NiCads had only leaked inside their cases with no spread, so they are out.
I think it will likely serve me well...the LEDs look good with only a little but of "shine" in the center line (where the middle of the 3 is...)
Steve
Top |
drworry
Post subject: Re: HP3465a bench meter Posted: Apr Fri 16, 2021 5:48 am |
Member |
BTW, does anyone try to replace those NiCAds? They appear to be AA size but solidly held in the 2 packs...
Steve
Top |
Mikeinkcmo
Post subject: Re: HP3465a bench meter Posted: Apr Fri 16, 2021 12:56 pm |
Member |
Joined: Oct Sun 15, 2006 12:57 pm Posts: 8273 Location: Liberty, Missouri 64068
Unless the Nicads are the primary power source for the meter, I'd not replace them. I know in some of their meters the power source was selected by a switch either on the rear panel or under the top cover.
_________________ Pics, Bold & underlined text, are usually links.
Top |
Barry H Bennett
Post subject: Re: HP3465a bench meter Posted: Apr Fri 16, 2021 1:05 pm |
Member |
Joined: Nov Wed 30, 2016 7:35 pm Posts: 12085 Location: Sunbury, Ohio 43074
In some of those bench units, the batteries need to be there as part of the power supply. I've replaced them in some, and in others just replaced them with a resistor selected the old fashioned way ... trial and error. But if the unit is using the battery pack as a filter, then you'll also need a capacitor somewhere to smooth out ripple.
Try it without the batteries and see. IIRC, my HP bench DMM just had an onboard jumper for whether or not it had the optional rechargeable battery installed. It's a 3466A
_________________ Preserving the hist. of electronics, one boat anchor at a time! :) https://www.bbtvtestequipment.com
Top |
drworry
Post subject: Re: HP3465a bench meter Posted: Apr Fri 16, 2021 2:37 pm |
Member |
This one is an "option 001", which runs on AC with optional batteries.
Interestingly, there is no description of how to remove the "optional" batteries in the manual, and the rear access door for the batteries has the usual "don't mess with me" warnings...and it was not obvious how to remove the door...
Unit runs fine without the batteries.
Thanks!
Steve
Top |
Barry H Bennett
Post subject: Re: HP3465a bench meter Posted: Apr Fri 16, 2021 2:41 pm |
Member |
IIRC, and I may not lol .... I had to dig into the schematics to figure out the "no battery" jumper. It wasn't mentioned anywhere in the manual that I could find. Likely a factory only option ......
Glad it works, nice meter.
Top |
Mikeinkcmo
Post subject: Re: HP3465a bench meter Posted: Apr Fri 16, 2021 8:14 pm |
Member |
AS for your original question about replacing electrolytics, I would test the cap for leakage, if you want something to do, but my experience has been that with lab grade test equipment, there is VERY SELDOM any need to replace electrolytics. Of the couple hundred pieces of test equipment I've repaired over the years, I replaced a filter cap in a Tek 7603(?), and a Boonton 260 "Q" meter. Now if it was a $15 table top AA5 from half a century ago, I'd replace everything I could. Has something to do with product build quality I think.
Top |
jimtech
Post subject: Re: HP3465a bench meter Posted: Apr Sat 17, 2021 5:30 pm |
Member |
The battery packs may be the same as used in old HP calculators. Here's an example of of a clone pack currently offered on eBay. The cost for a pair from that seller however, might be more then you paid for the meter. You could probably make up similar packs yourself from individual cells that you can buy that have pre attached solder tabs.
That said, this meter is probably best delegated to bench use anyway. Depending on the case style on yours, it's not highly portable in the first place, and operating time on batteries will likely be short even with new batteries.
- Jim
Attachments: |
Top |
Page 1 of 1
[ 10 posts ] |
Who is online |
Users browsing this forum: sdfzaqhp659 and 7 guests |
