It is currently Nov Tue 30, 2021 12:48 pm
 Post subject: Soft starting B+ voltage
PostPosted: Mar Fri 12, 2021 8:52 pm
Restoring a Silvertone 4588B floor model and is playing fine so far as it goes. The B+ voltage however surges past the 450V rating of the caps in the power supply. Surges about 560V from a cold start. Uses a 5X4 rectifier tube that is directly heated and gets ahead of the warmup of the other tubes till the B+ settles out around 375V.
Used an inrush current limiter in series with 5X4 filament. Takes about 30 secs for the radio to warmup but w/o the B+ surge. ICL device is an Amphenol CL-50, 7 ohms at 25C, max current of 5A. The 5X4 rectifier has a 5V 3A filament.
http://www.nostalgiaair.org/pagesbymode ... 017128.pdf
 Post subject: Re: Soft starting B+ voltage
PostPosted: May Fri 07, 2021 5:25 pm
What filament voltage does the 5X4 see after the warm up?
PostPosted: May Fri 07, 2021 5:58 pm
I use CL-90s on the incoming AC line to slow the turn-on and drop all the voltages to near where they should be. Todays line voltage is normally in excess of 120VAC, and as high as 126VAC which raises all circuit voltages, adds a lot of unwanted heat, and stresses all of the components...YMMV....73...Jordan VE6ZT
PostPosted: May Tue 18, 2021 2:39 am
+1 but it runs hot (by design), so try to mount on top of the chassis in some safe, ventilated housing!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: May Sat 22, 2021 5:09 pm
My recollection after 2 months is 4V.
PostPosted: May Sun 23, 2021 12:39 pm
2 months is a long warm up time LOL
