Page 1 of 1
[ 8 posts ] |
Author |
Don Cavey
Post subject: Question On A Cathode Resistor Used To Measure/Set Tube Bias Posted: Aug Wed 18, 2021 4:16 pm |
Member |
One way to measure accurately the current through the output tube of an amplifier is to break the connection between the cathode and ground. It is often advised to put a 10 Ω resistor between the cathode and ground and measure the voltage, use Ohm's Law and figure the current.
My question is, should that resistor be shunted with a capacitor to keep the cathode at AC ground as they do in a lot of small radios? Or is that value so low that it doesn't matter.
I hope that question makes sense.
Thanks.
_________________ Don
Top |
Tom Bavis
Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube Posted: Aug Wed 18, 2021 6:21 pm |
10 Ohms won't make much difference - it's tiny compared with the plate resistance of the tube. Yes, there's a little bit of negative feedback from it, reducing gain a tiny bit, but it's probably inside another feedback loop which will reduce gain by a tiny bit less than it would have without the resistor...
_________________ My web page: https://bit.ly/2rxq4qx
Top |
Don Cavey
Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube Posted: Aug Wed 18, 2021 6:44 pm |
Member |
Tom Bavis wrote: 10 Ohms won't make much difference - it's tiny compared with the plate resistance of the tube. Yes, there's a little bit of negative feedback from it, reducing gain a tiny bit, but it's probably inside another feedback loop which will reduce gain by a tiny bit less than it would have without the resistor... Thanks Tom, I figured as much. I appreciate your input.
Top |
Jordan390a
Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube Posted: Aug Wed 18, 2021 9:37 pm |
A lot of the guitar amp guys insert 1 ohm resistors from the cathode to ground. It makes no discernible difference, and allows for pretty simple calculations...!
73...Jordan VE6ZT
Top |
Mr. Detrola
Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube Posted: Aug Wed 18, 2021 10:05 pm |
A number of commercially designed amplifiers like the Eico ST-70 have unbypassed cathode resistors with jacks to do measurements while setting bias, and they work fine that way. I don't think you could possibly hear or measure any difference if they were bypassed.
_________________ Dennis
Top |
arbilab
Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube Posted: Aug Wed 18, 2021 11:23 pm |
Joined: May Sat 14, 2011 4:42 am Posts: 4245 Location: Ft Worth TX
Bias set with no signal? Amount of AC on cathode negligible?
_________________ "Enjoy the fair, George."
Top |
Don Cavey
Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube Posted: Aug Thu 19, 2021 12:16 am |
Member |
arbilab wrote: Bias set with no signal? Amount of AC on cathode negligible? Yes, the bias would be set with no signal. I guess there is minimal AC loss (with a signal) across the bias checking resistor.
Top |
engineer
Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube Posted: Aug Fri 27, 2021 6:58 pm |
Member |
Joined: Nov Thu 09, 2006 11:24 pm Posts: 3151 Location: Thornhill, Ontario, Canada
Mr. Detrola wrote: A number of commercially designed amplifiers like the Eico ST-70 have unbypassed cathode resistors with jacks to do measurements while setting bias, and they work fine that way. I don't think you could possibly hear or measure any difference if they were bypassed. At least one Heathkit power amplifier (W4M) has jacks in the o/p tube cathodes to allow a mA meter to be inserted to set bias. It scared me that the circuit could go open for some reason, sending the cathode voltage sky-high! As insurance, I bypassed each jack socket under the chassis with a precision 10 ohm resistor. Now a simple volt meter allows current balance to be set with no risks. Cheers, Roger
_________________ Roger Jones, Thornhill, Ontario Ontario Vintage Radio Assoc. http://www.ovra.ca
Top |
Page 1 of 1
[ 8 posts ] |
Users browsing this forum: No registered users and 2 guests |
