It is currently Aug Wed 17, 2022 10:18 am
 Post subject: Question On A Cathode Resistor Used To Measure/Set Tube Bias
PostPosted: Aug Wed 18, 2021 4:16 pm
One way to measure accurately the current through the output tube of an amplifier is to break the connection between the cathode and ground. It is often advised to put a 10 Ω resistor between the cathode and ground and measure the voltage, use Ohm's Law and figure the current.
My question is, should that resistor be shunted with a capacitor to keep the cathode at AC ground as they do in a lot of small radios? Or is that value so low that it doesn't matter.
I hope that question makes sense.
Thanks.
 Post subject: Re: Question On A Cathode Resistor Used To Measure/Set Tube
PostPosted: Aug Wed 18, 2021 6:21 pm
10 Ohms won't make much difference - it's tiny compared with the plate resistance of the tube. Yes, there's a little bit of negative feedback from it, reducing gain a tiny bit, but it's probably inside another feedback loop which will reduce gain by a tiny bit less than it would have without the resistor...
PostPosted: Aug Wed 18, 2021 6:44 pm
Thanks Tom, I figured as much. I appreciate your input.
PostPosted: Aug Wed 18, 2021 9:37 pm
A lot of the guitar amp guys insert 1 ohm resistors from the cathode to ground. It makes no discernible difference, and allows for pretty simple calculations...!
73...Jordan VE6ZT
PostPosted: Aug Wed 18, 2021 10:05 pm
A number of commercially designed amplifiers like the Eico ST-70 have unbypassed cathode resistors with jacks to do measurements while setting bias, and they work fine that way. I don't think you could possibly hear or measure any difference if they were bypassed.
PostPosted: Aug Wed 18, 2021 11:23 pm
Bias set with no signal? Amount of AC on cathode negligible?
"Enjoy the fair, George."
PostPosted: Aug Thu 19, 2021 12:16 am
Yes, the bias would be set with no signal. I guess there is minimal AC loss (with a signal) across the bias checking resistor.
PostPosted: Aug Fri 27, 2021 6:58 pm
At least one Heathkit power amplifier (W4M) has jacks in the o/p tube cathodes to allow a mA meter to be inserted to set bias. It scared me that the circuit could go open for some reason, sending the cathode voltage sky-high! As insurance, I bypassed each jack socket under the chassis with a precision 10 ohm resistor. Now a simple volt meter allows current balance to be set with no risks.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
