It is currently Dec Wed 01, 2021 10:26 am
 Post subject: Need clear plastic crack repair technique
PostPosted: Jun Thu 24, 2021 12:35 am
I've encountered several radio dial covers (the thick clear non flexible plastic type) that have hairline cracks in them. The cracks don't go all the way through, the covers are still sturdy, but the cracks stick out like a sore thumb, and no amount of polishing will reach them. Is there a product that might seep into these micro thin cracks to disguise them? Thought of using super glue, Plastipair (the liquid part only), or even plastic airplane glue, but don't want to make matters worse with the wrong method. Any suggestions of proven technique will be appreciated.
 Post subject: Re: Need clear plastic crack repair technique
PostPosted: Jun Thu 24, 2021 3:30 am
https://www.safelite.com/windshield-repair
PostPosted: Jun Thu 24, 2021 5:28 am
Safelite repairs glass; he's looking for a plastic repair method.
PostPosted: Aug Sun 08, 2021 8:08 am
I was hoping for an answer as well. I got a Knight CB Checker that has a cracked meter display.
On a YouTube comment it was suggested "Craftics Clear Acrylic Solvent Cement" specifically #1106002 but they have been out of stock for since I heard of it.
PostPosted: Aug Sun 08, 2021 8:59 pm
I have a National NC Sixty Special with a crack in the plastic. Been waiting for a sure fire fix. Seems like thin cyanoacrylate is a candidate. But how to ensure it goes all the into the crack? Because if it cures & only penetrated partway, the game is over.
PostPosted: Aug Thu 19, 2021 2:49 am
If someone comes up with a way to do this, repair plastic lens, and it not showing the crack they have won the lotto IMHO! I've tried cyanoacrylate with no luck other then making sure the crack is glued up. I have used instant glue in cracks in plastic and Bakelite cabinets. After I routed out the crack with my Dremel tool with a grinding bit in preparation to fill the crack for repair but for lens nope!
David
KN4VBT
PostPosted: Aug Thu 19, 2021 4:36 am
Super Glue ( cyanoacrylate ) isn't friendly to plastic most of the time it will frost over. However you may experiment. You could try clear epoxy.
Here a link that you can read about repairing cracks in plastics.
https://www.wikihow.com/Repair-Cracks-in-Plastic
There's even a suggestion about using Hot non-boiling water.
Or Clear nail polish https://ritely.com/nail-polish-hacks/
Visit our site:
I was smokinradios Long time ago (2004)
PostPosted: Aug Thu 19, 2021 5:50 am
Everyone has ideas about WHAT to put into/onto the crack but it seems to me that a critical part of the fix is how to ensure the chemicals of your choice actually penetrate the crack fully, both longitudinally and depth. I imagine there'd be nothing more frustrating than to apply the magical elixir but when it has set there's still a feathery end of the crack that was never penetrated & may now be sealed off from further access.
PostPosted: Aug Thu 19, 2021 10:31 pm
I don't see how a crack in plastic, and ESP clear plastic, can be made invisibly.
It's the same as Bakelite in that regard, where the two sides might be joined together W/O any noticeable trace of the bonding agent (that pretty well leaves out Crazy Glue), but there will still be a visible hairline.
PostPosted: Aug Thu 19, 2021 11:35 pm
[quote="Radiosmoker"]
I like the tip listed about using acetone and scrap plastic to make a slurry to repair cracks. Never knew you could do that so you do learn something new everyday, thanks. Yet with all these tips on how to repair plastic none of them achieve what the OP is looking for a clear plastic crack repair that doesn't show.
David
KN4VBT
PostPosted: Aug Thu 19, 2021 11:39 pm
Vacuum.
PostPosted: Aug Fri 20, 2021 12:25 am
Vacuum
I've thought something like that might help. Have you done it? Details? Vacuum chamber? Vacuum on one side? How much vacuum? There may be only one shot at getting it right for the piece to be repaired.
If a chamber, seems one must apply the cement/glue/solvent before closing in a vac chamber & pumping down, so there's a bit of a race between cement/glue/solvent set-up time & the time needed to do the vacuum trick.
PostPosted: Sep Mon 06, 2021 5:20 am
Some of us can remember getting model glue on the windshield of a plastic model, ugly.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Sep Wed 08, 2021 8:03 pm
Have you tried Mark Palmquist? He might have a repro for your radio. www.dialcover.com
Post New Topic Post Reply  [ 14 posts ]  Moderator: Peter
