It is currently Jan Mon 24, 2022 8:28 am
 Post subject: Clearcoat a 50's plastic Philco cabinet
PostPosted: Aug Sun 22, 2021 2:52 am
I'm going through a Philco H765 and the black plastic cabinet was kind of scratched up. I decided to sand it an clearcoat it.
I sprayed it with clear gloss lacquer like I do for bakelites. Bad idea.
The plastic reacted and the surface acquired a fine grainy finish, like on a camera.
So I've had fun sanding the entire thing down to where I can try again.
What kind of plastic is that cabinet made of, and what paint can I use that won't cause that reaction? I just bought a can of Krylon ColorMaxx that's supposed to be safe on plastics, but I tested it on the inside of the cabinet and got the same result.
Joe T.
Antique Radio Collectors
and Historians of Greater St. Louis
www.archradioclub.org
 Post subject: Re: Clearcoat a 50's plastic Philco cabinet
PostPosted: Aug Sun 22, 2021 1:18 pm
I think it's polystyrene. Not sure what paint to use, sorry.
Peter
PostPosted: Aug Sun 22, 2021 1:35 pm
Use an auto enamel primer (not lacquer) for a basecoat, then colour of choice (also enamel) over top of the primer. Lacquer is pretty aggressive for some plastics. Enamel is an easier spray from rattle cans and much less harsh.
.... just my experience ....
PostPosted: Aug Mon 23, 2021 2:44 am
Thanks for the replies. Polystyrene makes sense, and there is a lot of information on the web about painting styrofoam.
I'll get some clear enamel and give that a whirl. I'll post what I find.
Joe T.
PostPosted: Aug Mon 23, 2021 7:03 am
Site Admin
Shellac. I know this is my answer to everything, but it works because it used a different solvent than g your print does and will isolate the solvent from the plastic below.
Plus, you can quickly remove it cleanly of you don't like it
PostPosted: Aug Wed 25, 2021 6:33 pm
Peter
If it is polystyrene, use Testors Gloss-Coat. It is specifically formulated for going on plastic models, which are also polystyrene.
Brett
PostPosted: Aug Wed 25, 2021 7:24 pm
Brett - I had the same idea - model paint. I inadvertently inhaled a lot of model paint solvents when I was a kid and I think radio collecting is one of the long-term side effects. :D
Yesterday I was standing in the model aisle at Hobby Lobby and looked at exactly what you recommended:
I saw the word "lacquer" and ran away. But it's not really lacquer. If you look at the MSDS on Testors' website - https://www.rustoleum.com/MSDS/ENGLISH/1261T.pdf - we learn a couple of things:
1. Testors is made by Rustoleum
2. It still has acetone in it.
3. It's designed for styrene models, so it should be OK. But I don't want to trash my cabinet again.
That's what's so maddening about this problem, but another member of the local radio club had a brilliant suggestion. Rather than spray the cabinet, test drive the paint on styrofoam cups.
I'll get a little can of the Glosscoat and try it out.
Joe T.
PostPosted: Aug Fri 27, 2021 12:37 am
Inadvertently, eh? Stick to that story.
I have had the same experience with model airplane dope, and not just as a kid - as recently as this last weekend. Didn't do me any harm, made me what I am today.
Brett
PostPosted: Sep Mon 06, 2021 5:06 am
To test spray paint, shoot some in a cup, then brush it on, a bit under the chassis.
I've done this to mix 2 colors as well, such as needing to touch-up nicks or scratches with a tiny brush.
Burl Ives, RIP, oldtimer.
[:l>)
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter
