It is currently Jan Fri 21, 2022 3:25 am
 Post subject: Use power transistor for TDA2030 audio amp?
PostPosted: Aug Thu 26, 2021 10:16 am
Hi, all
Recently, I am attempting to make a Stereo Power Amplifier using two TDA2030A (data source: https://www.apogeeweb.net/circuitry/TDA2030-application-circuit.html).
I want an output of at least 25 watts per channel. The datasheet shows me that I need to add a pair of power transistors, BD907 and BD908 if I want my amplifier for higher power output. There are two circuits shown below and the one with the power transistors outputs more power. My question is this. Can I replace these BD907/908 with TIP35C and 36C , which are more easily available?
I have purchased a transformer of 24V-0-24V, 80VA.
 Post subject: Re: Use power transistor for TDA2030 audio amp?
PostPosted: Aug Thu 26, 2021 1:57 pm
Piperlin wrote:
Can I replace these BD907/908 with TIP35C and 36C , which are more easily available.
The TIP parts have higher ratings and should work without any obvious issues.
Curtis Eickerman
Users browsing this forum: cadlac84, Majestic-12 [Bot], Paul Dietenberger, Pbpix, tubes4life and 16 guests
