It is currently Jan Thu 27, 2022 11:38 pm
 Post subject: Iron re veneering
PostPosted: Aug Tue 31, 2021 1:33 pm
I've done iron re veneering quite a few times. Every now and then I still get some unattached small areas. Could it be that 1 layer of glue on each surface is not enough? Anyone tried 2 layers of glue? Thanks.
 Post subject: Re: Iron re veneering
PostPosted: Sep Wed 01, 2021 10:37 am
Site Admin
If anything, you glue was applied to thickly. You want as little as possible.
PostPosted: Sep Thu 02, 2021 12:45 pm
Glue failure can be caused by dust and dirt along with oil and grease. Dust down all surfaces closely with an airline.
Use a good quality regular white PVA adhesive (not the waterproof stuff) and apply a very thin coat first and allow it to become dry to the touch - - if it's too thick, you can wipe most of it off with a clean slightly damp lint free rag - - then apply a moderate amount evenly.
I use a high destiny foam mini roller, the ones with the rounded edges.
Preparation is paramount when veneering... and never veneer over old veneer.
PostPosted: Sep Fri 03, 2021 11:17 pm
There are videos on ironing on veneer using yellow wood glue, I used Titebond. First gluing both sides, then letting the glue set for an hour or so, positing the veneer onto the radio and ironing it down, using medium high heat. I did this on a German radio and found don't use high heat, use just enough, and it'll work. I have a Airline 62-306 with a curved front I'm going to try next, almost all of the veneer on it is bad.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter
Users browsing this forum: Google [Bot] and 9 guests
