It is currently Nov Sun 28, 2021 6:58 am
 Post subject: PRESTO 85-B (cutting) amplifier infos needed
PostPosted: Sep Thu 09, 2021 3:26 am
Hi,
I'm currently in the process of restoring a very old PRESTO 85B (disc cutting) amplifier. It's a big rackmount unit, basically a simple transformer coupled push pull amp using (2) 6L6G's and (4) 6SJ7's. The problem is that the unit in my possession has been heavily modified and I would like to put it back to its original condition, or at least as close as possible. Unfortunately the only (hand drawn) schematic available on the web is incorrect and I was unable to find any more informations about this amp so far.
Thus, if you have the (original) PRESTO 85B schematics and/or manual in your files I would greatly appreciate If you could post a scan, or alternatively a web (link) source where I could buy a copy of the 85B manual.
Thanks to all for your help.
 Post subject: Re: PRESTO 85-B (cutting) amplifier infos needed
PostPosted: Sep Thu 09, 2021 5:13 am
This place claims to have 85A &E information (I think the difference for the B was being rack mounted), for $15.
http://www.prestohistory.com/Presto4.html
I know nothing about them.
Is this the site with the hand drawn schematic you believe to be wrong? https://www.omroepmuseum.be/index.php/4 ... presto-85b
Curtis Eickerman
PostPosted: Sep Thu 09, 2021 5:25 am
After doing a Google Translate on the website with the hand drawn schematic I found that they said, "It was also revealed that a lot of changes had been made to both devices, making it practically impossible to bring them back to their original state. (After all, as far as we know, there is no original diagram or document available about this). "
So, not sure about the other site that says they have a schematic.
Curtis Eickerman
PostPosted: Sep Thu 09, 2021 1:01 pm
Great project, and I hope you are successful. I was just reading an old electronics magazine that mentioned their next issue would go into the details of the Presto, but the article did not say specifically what model. I'll see if I can dig up the "next" issue, but it probably won't be till after Kutztown.
best...
PostPosted: Sep Thu 09, 2021 5:08 pm
Have a PDF manual for the Presto 90-B recording amplifier if you'd like it
PostPosted: Sep Fri 10, 2021 6:39 pm
Curtis Eickerman
Thank you for your help. I already went to this website and since I understand dutch (flemish) I had no translation issues. My 85-B is very likely from the same origin and cosmetically in poor shape (mostly dust and grime) but with all transformers tested good. Electrical restoration is allmost complete but there are still some unknows regarding some parts values and circuits changes which are different from the (hand drawn) schematic posted.
I'll keep searching and will post pictures of the restored amp when finished.
PostPosted: Sep Fri 10, 2021 6:49 pm
Thank you for your kind offer, but I think the 90-B has a completely different circuit inside.
PostPosted: Sep Fri 10, 2021 6:54 pm
best...
That would be nice... maybe there was an article in an old issue of Audio or other (Hi-Fi, broadcast,...) magazines. I can't date this amp but I would guess something like mid 40ies - early 50ies, this should help narrowing your search.
PostPosted: Oct Wed 06, 2021 12:09 am
You might try looking at David Bogen for sources of the 85B schematic,
not sure if the companies had merged by the time of your amp's manufacture or not.
I've come across the presto cutting amps in old radio and audio mags as well, but there's a lot to go through to check.
The American radio history (or world radio history?) site may have catalogs and copies of those mags,
if we knew the year/date of product release or manufacture of the 85B that would be helpful in finding an article (w/schematic) on that model.
"How come we never watch Television?" - sonuva TV repairman in the fifties, Mac Rebennack.
PostPosted: Oct Wed 06, 2021 12:30 am
Thank you for your help and suggestions. I think the Bogen-Presto merging came much later, well after this amp was manufactured. (I would roughly date it circa 1947- 1955) My exemplar is S/N 2404, if that could help. I checked all my old issues of AUDIO and FM/TV magazines of that period but found nothing (but a few small adverts) about the 85B. Since this amp was a part of a disc cutting system maybe something could be found in a specialized magazine about (disc) recording but I have no idea if there ever was such a magazine.
I found a few Presto schematics in Oliver Read's The Recording and Reproduction of Sound but unfortunately nothing about the 85B. Maybe another book about recording/disc cutting has more infos ?
PostPosted: Oct Thu 07, 2021 2:30 am
I looked through a bit of my catalog collection and came across this ad clipped from a 1949 Newark catalog,
showing the 87A amplifier. I would hazard to guess the 85B is a year or 2 older in date of manufacture, does the "2-piece" unit shown here look at all
like the 85B in cosmetic appearance?
