It is currently Nov Sat 27, 2021 10:34 am
 Post subject: Dual 1229:Engaging Stop lever will not get cam to cycle
PostPosted: Sep Mon 13, 2021 4:32 am
Hello folks. I just got done going through and re-cleaning and checking parts involved with Stop function because cam won't cycle. Auto start works fine, but I still can't get cam to cycle after engaging Stop lever. After staring cam cycle by hand, Stop function works as it should, i.e., tonearm lifts and returns to rest and unit shuts off. Anyone have any thoughts? Many thanks!
 Post subject: Re: Dual 1229:Engaging Stop lever will not get cam to cycle
PostPosted: Sep Mon 13, 2021 5:02 am
https://www.youtube.com/watch?v=O0J9gf7J3MQ
Here, Watch this
PostPosted: Sep Mon 13, 2021 5:20 am
Hey Davek65. Thanks for the speedy reply. Unfortunately, the video you provided a link to does not address the trouble I'm having. The auto return works fine on my 1229. It's the Stop function that is not working. The Stop function is supposed to lift tonearm off of the record at any point and return it to rest and shut down motor. Regards, -Paul
PostPosted: Sep Tue 14, 2021 3:51 am
https://www.audioservicemanuals.com/d/dual/dual-1219/6780-dual-1219-1229-service-manual
Here's a free service manual . Sounds like its in the clutch.
PostPosted: Sep Tue 14, 2021 3:40 pm
Please enter this forum, you can ask in english and you get help in english!
There are the experts:
https://www.dual-board.de/
Register:
Click on "Registrieren" and "Benutzerkonto erstellen".
Good luck!
SIXMILLION DOLLARMAN
PostPosted: Sep Sun 19, 2021 3:28 am
Have you removed the cam wheel and cleaned/relubricated the velocity trip pieces on the camwheel? It is likely that the damping grease has dried out, causing the trip to not position properly. Has this turntable been overhauled? I've never seen one that didn't need a teardown to remove the old congealed grease that is everywhere in the mechanism.
John Stone
Users browsing this forum: crtkecnkl659 and 6 guests
