It is currently Nov Sat 27, 2021 3:01 am
 Post subject: WTB capacitor checker, it-28 or equivalent?
PostPosted: Sep Wed 15, 2021 3:41 pm
Hi, looking for a cap checker that is a reasonable price to check big power capacitors.
Anything out there?
Thanks!
- Jeff
 Post subject: Re: Wtb capacitor checker, it-28 or equivalent?
PostPosted: Sep Wed 15, 2021 4:26 pm
IT-28s are going for $300 on Ebay thanks to audiophools. Good luck in your search.
PostPosted: Sep Wed 15, 2021 5:57 pm
I have a Pyramid CRA-2, complete with hard copy manual,that I have carefully restored that I’ll let go for $100 + actual shipping (I have packing materials already).
Based on the info you have supplied, I can’t be sure this will meet your needs. I can send a crude PDF of the manual as well, but here’s a photo of their original advertising that gives you the basics of its capabilities.
73, de Chuck K4CCW
PostPosted: Sep Wed 15, 2021 6:33 pm
I think it depends upon your needs...do you need to be able to reform/refresh eletcrolytics? If not, then woodchuck's make sense. If so, then be looking at $200+ these days
Steve
edited: The pyramid, from the manual...I have not seen one...appears to be a rather neat variation from the idea of a Tel-Ohmike...
Should work fine for reforming. I would like to see one!
PostPosted: Sep Wed 15, 2021 7:17 pm
Some reforming, mostly going to be used for leakage testing of larger caps, 29-50,000 uf at 40-85 Volts max. I just liked the way the it-28 worked for leakage with the eye tube. Made it nice and easy to test.
- Jeff
PostPosted: Sep Wed 15, 2021 10:22 pm
Here is a link to a PCB for a capacitor DC leakage tester:
https://www.antiquewireless.org/homepage/pcb-item-4/
 Post subject: Re: WTB capacitor checker, it-28 or equivalent?
PostPosted: Sep Thu 16, 2021 5:50 am
Just remember, most capacitor testers are not rated for reforming capacitors. Use a power supply and a ma meter and save the tester transformer from going up in smoke.
DM
PostPosted: Sep Thu 16, 2021 7:49 am
And most of the old capacitor testers don't go above 5000 uF.
PostPosted: Sep Thu 16, 2021 9:35 am
Site Admin
This is not a discussion forum. If you're not buying or selling, comments need to be via PM or be put in another section
PostPosted: Sep Fri 17, 2021 5:02 am
I have a nice Senecor, very substantial.
Tried to PM, but something wrong.
Please PM me and I'll give details.
Wilson
PostPosted: Sep Sat 18, 2021 7:27 pm
still looking
PostPosted: Sep Wed 22, 2021 2:45 am
It's a Semcor I have, HA-115, $100.
Wilson
Post New Topic Post Reply  [ 12 posts ]  Moderators: Alan Voorhees, Philco Fan
Users browsing this forum: crtkecnkl659, jackpineradio and 28 guests
