It is currently Jan Tue 18, 2022 4:52 pm
 Post subject: PACO E-200 Signal Generator Information Requested
PostPosted: Sep Sat 18, 2021 11:12 pm
Hi,
I'm looking for a manual and/or schematic for an E-200 (no alpha suffix) that covers SN 15960.
Thank you in advance,
Ross
 Post subject: Re: PACO E-200 Signal Generator Information Requested
PostPosted: Sep Sun 19, 2021 5:34 am
Radio Museum has the schematic. Can't tell how good a copy it is.
https://www.radiomuseum.org/r/precis_2_e200_signal_generator_e20.html
A complex machine that works evolved from a simple machine that works
PostPosted: Sep Sun 19, 2021 6:55 am
There were 2 possibly 3 versions of the first E-200, not counting the B and C versions. The schematic you need should be here.
https://bama.edebris.com/manuals/paco/e200/
DM
PostPosted: Sep Sun 19, 2021 5:15 pm
The second schematic in this set should cover your E-200. It would it interesting to know if it doesn't, and if so, what the differences are.
https://www.byan-roper.org/steve/manual ... matics.pdf
Here's the corresponding set of parts lists:
https://www.byan-roper.org/steve/manual ... onents.pdf
This article written by Precision's Chief Engineer G. N. Goldberger should provide much of what you need to know with respect to a manual:
https://www.byan-roper.org/steve/manual ... 940-05.pdf
There is also Goldberger and Robinson's "Servicing by Signal Substitution" book. The version I have scanned is for the E-200-C, but it also covers the E-200 and includes schematics for it.
https://www.byan-roper.org/steve/manual ... tution.pdf
You'll have to keep the more limited frequency range of the E-200 in mind when reading it, though. The E-200 won't cover the modern FM band, while the E-200-C does.
This E-200 restoration thread may or may not be helpful:
https://antiqueradios.com/forums/viewtopic.php?t=379425
Here's a thread with a bit of history on the Precision E-100, E-200, E-200-C, and E-200-D signal generators.
viewtopic.php?f=8&t=363695
PostPosted: Sep Sun 19, 2021 5:16 pm
I hadn't previously seen any reference to an E-200-B. Do you have any links to information on it?
PostPosted: Sep Sun 19, 2021 7:49 pm
Thank you all. I love this forum. I'll check these out and get back with what may be different.
Thanks again,
Ross
Users browsing this forum: keith49vj3, PaulAm, Tubelover, Usually Lurking, yo0 and 4 guests
