It is currently Jan Thu 20, 2022 6:34 am
 Post subject: FS tranformer
PostPosted: Sep Mon 20, 2021 7:48 am
F.S. Power transformer
There are no markings on the case, so I picked a side and gave it numbers
and letters, to I.d. things.
6 and A are the a. c. in. I had 117 volts in. Measuring 6 to B , I see 110 volts.
It looks like a tap.
C to D is 5 volts, and E to F is 818 volts, center tapped connection is on the
inside of the card board.
1 and 3 have 2.8 volts, and 2 is a center tap for that. 4 and 5 are 2.8 volts.
The case is grounded, keep that in mind for your install. I did not find any
shorts .
The bolt centers are 2 ¼ by 4 ¼ inches, the case is 3 ¾ by 4 ¼ by 5 inches,
and she weighs in at 7 ¾ pounds.
If you have a question I will try to get you an answer quick.
Asking 35.00 plus shipping,
 Post subject: Re: FS tranformer
PostPosted: Sep Mon 20, 2021 4:14 pm
Undoubtedly from a late 1920s or early 1930s radio, with 2.5 volt tubes. The center tapped filament winding would be for the output tube(s), with the tap used for a bias resistor.
PostPosted: Oct Fri 01, 2021 12:26 am
Thanks Tim, I knew that someone would have a better idea of the what and why. :)
Post New Topic Post Reply  [ 3 posts ]  Moderators: Alan Voorhees, Philco Fan
Users browsing this forum: studioguy and 5 guests
