It is currently Dec Sun 05, 2021 9:03 am
 Post subject: Integrated Circuit LS1800
PostPosted: Sep Wed 22, 2021 3:30 pm
Hi
Has anyone come across this IC LS1800 and found any data on it?
I have a kids "AM/FM Sing-A-Long Radio". It is a TRF with a C9014 transistor, UTC7368 audio power amplifier and the LS1800.
The LS1800 is a 22 pin DIP.
The radio works very well for what it is and is very sensitive.
thanks
Allan
 Post subject: Re: Integrated Circuit LS1800
PostPosted: Sep Wed 22, 2021 5:40 pm
That number doesn't sound right to me. Can you post photos of the unit and the chip?
PostPosted: Sep Wed 22, 2021 6:19 pm
It's LA 1800 made by Sanyo. I've seen some basic low part count am/fm kid/novelty radios that are poor performing low cost. The data sheet has this simple circuit.
Ken
PostPosted: Sep Wed 22, 2021 6:20 pm
Here are photos of the circuit board
Allan
PostPosted: Sep Wed 22, 2021 10:19 pm
National had the LM1800, but that was a stereo decoder.
There were some 18xx numbered ICs that were most of an AM/FM receiver, but surekly a second source would use the same number.
No IF transformers, and I see no ceramic filters. Not much to make a radio unless they are on the other side of the board.
There are ICs for making simple FM receivers, using active filters at a low IF. "7088" comes to. mind. But those use two buttons, and scan the band, until an fm signal is found.
There are also 3 terminal TRF radios for the AM broadcast band, descended from the ZN414. Those need a variable capacitor.
But I've yet to come across an IC that integrates both.
PostPosted: Sep Wed 22, 2021 11:18 pm
I think Ken figured it out.
https://pdf1.alldatasheet.com/datasheet-pdf/view/39992/SANYO/LA1800.html
Ted
PostPosted: Sep Thu 23, 2021 2:04 pm
On the underside of the pwb, there is only one small capacitor which is attached to the tuning capacitor.
Looking at the pwb wiring and the circuit for the LA1800, I think that my LS1800 is a LA1800 with a different number.
Thanks to all who responded.
Allan
Users browsing this forum: F6HOY and 3 guests
