It is currently Jan Fri 28, 2022 9:33 pm
 Post subject: Zenith 6V27 Vibrator
PostPosted: Sep Fri 24, 2021 8:27 pm
I am restoring a Zenith 6V27 radio and discovered the vibrator was removed. According to my research, an ATR 522, Mallory 246 or Radiart 5411 are direct replacements. However, I have been unable to find any of these for sale. Are there other types that would work or does it need to be a direct replacement?
 Post subject: Re: Zenith 6V27 Vibrator
PostPosted: Sep Fri 24, 2021 9:48 pm
You want this one? It’s an original. It worked when I took it out of the radio 17 years ago
PostPosted: Sep Sat 25, 2021 12:14 am
Sure, will take it. What do you want for it?
PostPosted: Sep Sat 25, 2021 12:37 am
Will PM you
PostPosted: Sep Mon 27, 2021 3:10 am
I have many vibrators, buffer caps, OZ4s, and even eye tubes if you cannot locate same. Denis
PostPosted: Sep Mon 27, 2021 5:32 am
You may be better off building a S.S substitute over the long run, I found an Australian site with instructions on building a S.S synchronous vibrator, though you may have to look up EIA substitutes for some of the part numbers they have listed:
http://www.zc1-radioclub.org.nz/page70.html
Regards
Arran
P.S Correction, it's a New Zealand site, it was the first time I looked at it in six months.
PostPosted: Sep Mon 27, 2021 11:34 am
I built my own SS vibrator using a very similar circuit for my 6v27. Seems to work well with no transformer heating.
PostPosted: Sep Mon 27, 2021 2:13 pm
Regards
Arran
Oh dear! They will not be pleased. That's a "New Zealand" publication, they're a bit East of us across a little ditch called the "Tasman Sea".
Marcc
Post New Topic Post Reply  [ 8 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: Chris108, fixt, lkopvbgf786, moparguy, RadioMan1954 and 6 guests
