It is currently Dec Thu 02, 2021 1:33 pm
 Post subject: NOS AK Breadboard/Cord?
PostPosted: Sep Tue 21, 2021 1:38 am
Greetings-
Picked up an Atwater Kent breadboard 10A model 4550 that had the end of the cord wrapped in a manner that looked like it could be factory. I've attached pictures below. I believe at least the cord could be new old stock. The only thing I was told was this was sitting in an attic for years and came with BB tipped 201a tubes that have good filaments. I will check audios and emissions later.
 Post subject: Re: NOS AK Breadboard/Cord?
PostPosted: Sep Tue 21, 2021 2:27 am
Could easily be the original, it looks just like the one on mine.
PostPosted: Sep Tue 21, 2021 3:16 am
This looks like a Win Win,with good BBTT 01A's.The underside looks untouched,need pictures of the top.
Andrew
PostPosted: Sep Wed 22, 2021 1:50 pm
Looks to be oroginal to me! Great find!
http://pages.suddenlink.net/davesradios/
PostPosted: Sep Wed 22, 2021 5:01 pm
If original, they did a crappy soldering job on it. My guess is not original.
PostPosted: Sep Thu 23, 2021 5:20 pm
Post a photo of the connections end of the cord, that would help.
Dan
Museum Curator
PostPosted: Sep Fri 24, 2021 1:20 am
The problem is I would have to unwrap it. I am considering leaving it alone as proof it is NOS - at least the cord. Both audios are good so I believe it likely hasn't been used much - if at all. Its been stored in an attic so it has nearly 100 years of dirt and patina, but no real wear. The paint looks aged for sure. Unless I just unwrap a small piece at the end. Thinking about doing that because I am curious.
PostPosted: Sep Sun 26, 2021 12:00 am
Some more pictures
PostPosted: Sep Sun 26, 2021 4:33 am
Gorgeous!
PostPosted: Sep Sun 26, 2021 7:21 pm
If the cable has never been unwrapped I would expect a little yellow tag attached to the bloody end, secured with a knot on the tail of the outer braid.
My AK 10-C has the remains of such a tag and the picture I am attaching is from a virgin AK-20 installed in a cabinet and the label has rarely seen light of day.
This shows the correct battery voltages for the color of the wire in the cable.
Jim
PostPosted: Sep Sun 26, 2021 9:58 pm
Sounds like you have a rare virgin unit and you probably should hold on to it. I believe my radio's cord is at least NOS. There could be a tag wrapped underneath as I think the connecting wires are folded over and there is something around them. I'm tempted to at least cut off part of the wrap and see.
Post New Topic Post Reply  [ 11 posts ]  Moderator: sofaslug
Users browsing this forum: wazz and 8 guests
