It is currently Dec Mon 06, 2021 4:20 pm
 Post subject: Ayuda con diagrama radio Geloso
PostPosted: Sep Fri 24, 2021 1:21 pm
Important: I use Google translator.
I don't use local idioms in writing.
Please help me to locate a diagram of this Geloso brand radio and turntable.
Valves: ECH42; EF41 (2); EBC41 (2); EL41 (2); 6U5 and 5Y3 .
Model 2604 Band Selector Key Block.
As can be seen in the photos, there is a lot of work to be done, with the naked eye, bad + B electrolytes and many bad Hydra axial capacitors.
From already thank you very much.
From the South of the Americas, Montevideo, Uruguay, greetings!
Pablo Oddone
 Post subject: Re: Ayuda con diagrama radio Geloso
PostPosted: Sep Fri 24, 2021 2:01 pm
Have you checked on this site: https://www.nvhr.nl/frameset.htm?schema ... ntentFrame
Jay
PostPosted: Sep Fri 24, 2021 3:08 pm
Type Geloso in the Marque box, and hit Enter on your keyboard.
https://www.doctsf.com/
PostPosted: Sep Fri 24, 2021 3:14 pm
As Jay has mentioned above.
Go to… Schema's
Type Geloso in the Merk box, and hit Zoeken.
PostPosted: Sep Fri 24, 2021 9:54 pm
I would go to the recommended sites above. The Geloso radio would be a rare or unusual item in North America, but sometimes Canada has radios that I have never heard of and were not sent to USA.
PostPosted: Sep Sat 25, 2021 1:42 pm
Hola Pablo,
Actually, are you sure this radio was made by Geloso?
The only thing we know is that the "block" assembly (coils and selectors) was provided by Geloso, but it may very well have been integrated by another manufacturer.
A clue that confirms my doubt is that there seems to be English-made and German-made capacitors - not the type Geloso would use in its sets, I reckon.
You should search on http://www.doctsf.com or http://www.radiomuseum.com using the list of tubes without the brand...
Could you also post a picture of the cabinet?
Experience is directly proportional to the amount of equipment ruined. (Harrisberger's 4th Law)
PostPosted: Sep Mon 27, 2021 5:12 pm
Chris Don wrote:
Hola Pablo,
Important: I use google translator.
I do not use local idioms in writing.
First of all, thank everyone for the help provided.
I will tell you, in Uruguay, GELOSO had a plant for the assembly of various models of radios and combinations since the 1940s.
But I have the doubt that it is a gelossal receiver
I consider it more real that it has been assembled by a technician in his workshop and then commercialized.
I looked at RadioMuseum but with the valves it has, I get various diagrams, but none is 100% the same as the chassis I have under repair.
Thanks again and I will upload photos of the cabinet as soon as possible, they did not bring it to the workshop, instead I only received the chassis.
PostPosted: Sep Mon 27, 2021 6:08 pm
Nevertheless, the dial looks Italian: names of cities in Italian, Italian cities in blue... And is definitely Geloso style!
PostPosted: Sep Mon 27, 2021 7:25 pm
It looks like a cost reduced version of this radio:
From the site I recommended above.
Jay
Post New Topic Post Reply  [ 9 posts ]  Moderator: sofaslug
Users browsing this forum: Granite Radios, LarryFS, oldtvsandtoys and 16 guests
