It is currently Jan Tue 25, 2022 3:04 pm
 Post subject: Loctal-8 tube question
PostPosted: Sep Tue 28, 2021 12:52 am
My basic query of the week, using as an example, a 7A8 tube, in which stem is not phenolic, yet under chassis there are connections to it. Is it a negative or does the stem play an actual active part in the scheme of things?
 Post subject: Re: Loctal-8 tube question
PostPosted: Sep Tue 28, 2021 1:55 am
The metal base of the Loctal tubes acts as a shield and a connection for an additional shield if needed. The base is usually connected to the radio chassis.
Jay
PostPosted: Sep Tue 28, 2021 10:28 pm
I noticed this on some of the radios I work on. The ones where B- does not go to the chassis, They tie them together and then to the chassis. Only on the RF/IF tubes. The Detector and Output tubes have no wires connected to that tab. So it must be for shielding as Jay said. Some of the 7 pin fiber sockets have those center tabs and you will find them also all tied together and grounded to the chassis. They look like a little rivet yet the tubes are all glass. Seems like a lot of extra work for the assembly line. The engineers are a lot smarter then I for sure, so there must be a good reason.
Freeman
Post New Topic Post Reply  [ 3 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: Google [Bot], lkopvbgf786 and 34 guests
