It is currently Feb Wed 26, 2020 5:27 pm
 Post subject: building a enclosure for home made amp
PostPosted: Nov Sat 11, 2006 1:18 am
i build a amplifier kit and would like to mount it in a metal box. what do you reccomend the best ways of lining it up and drilling the holes for the inputs volume control and tube sockets.
PostPosted: Nov Sat 11, 2006 2:31 am
Is this a printed circuit board amp? It easiest to get the measurements from a bare PC board, but if it's assembled it should still be possible. Mounting holes need to be exact, but you can probably use oversize holes for the sockets - it will give some ventilation too. Maybe pots and inputs can just be oversize clearance holes too. A "step drill" is the best way to make large holes - Harbor Freight has a cheap set that should do.
